Azurit Firmware (English)
- 1 Download and flash Arduino code
- 2 Settings
- 3 First-time usage
- 4 Starting the mower
- 5 Console output
- 6 Motor controller (PID)
- 7 Bluetooth module
- 8 Diagnostics/troubleshooting
- 8.1 Hardware measurements
- 8.2 Error codes
- 8.3 I2C errors
- 8.4 Disable all pins not connected
- 8.5 Motors working correctly
- 8.6 Any unexpected sensor triggering
- 8.7 Some sensor not triggering?
- 8.8 Bluetooth not connecting?
- 8.9 Robot not stopping to rotate when reaching perimeter (home mode)
- 8.10 More trouble shooting
- 9 Sensor logging
- 10 How to report a new bug/new feature/new code
- 11 Charging
- 12 IMU
- 13 IMU calibration steps
- 14 Perimeter receiver
- 15 GPS
- 16 Timer
- 17 Drop sensor
- 18 Finite state machine
You have two options:
Important for Arduino IDE 1.6 or higher: if you see any folders inside the code folder (e.g. 'unused'), please delete them before compilation! Note: Always verify that the pin configuration in your Arduino code (config.h/mower.cpp) matches your actual circuit!
First-time usage
2. The software offers a serial console mode. Open the serial console in the Arduino IDE (CTRL+SHIFT+M) and set the baudrate to 19200. The motor and sensor values should appear constantly. First let's delete any existing error. Send the letter 'd' to the Arduino.
pres... 8=ADC calib (perimeter sender, charger must be off)
4. Save user settings
press... 9=saver user settings
5. Test motors:
press... 1=test motorsSecurity note: For security reasons, always remove mower blades in your first tests!
Starting the mower
Console output
--- commands ---
Bluetooth module
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
Communication protocol
Sensor logging
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes
ERR_CPU_SPEED CPU speed error
ERR_IMU_TILT IMU tilt error
* Check coil polarity
* Check left odometry cable
* Check left motor direction
* Check right odometry cable
* Check right motor direction
ERR_BATTERY Battery error
* Check battery connections
ERR_CHARGER Charger error
* Check charger connections
* Check GPS cables
ERR_GPS_DATA GPS data error
* Check GPS antenna and cable
I2C errors
Sensor logging
Charging
IMU
IMU sensor fusion
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
GPS
Currently, GPS is used
Visualization of GPS data
GPS error
Timer
Timer 3: off
Timer 4: off
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Dropcontact = 1; ändern in 0
Implemented updates:
