Azurit Firmware (English)
- 1 Uploading the Arduino code to your Arduino
- 2 Settings
- 3 First-time usage
- 4 Starting the mower
- 5 Console output
- 6 Motor controller (PID)
- 7 Bluetooth module
- 8 Diagnostics/troubleshooting
- 8.1 Hardware measurements
- 8.2 Error codes
- 8.3 I2C errors
- 8.4 Disable all pins not connected
- 8.5 Motors working correctly
- 8.6 Any unexpected sensor triggering
- 8.7 Some sensor not triggering?
- 8.8 Bluetooth not connecting?
- 8.9 Robot not stopping to rotate when reaching perimeter (home mode)
- 8.10 More troubleshooting
- 9 Sensor logging
- 10 How to report a new bug/new feature/new code
- 11 Charging
- 12 IMU
- 13 IMU calibration steps
- 14 Perimeter receiver
- 15 GPS
- 16 Timer
- 17 Drop sensor
- 18 Finite state machine
- Download an Ardumower Release at Github
- Download the Arduino IDE that we will use to upload the code to your Arduino
- Start Arduino IDE, and choose the right Arduino board (either Mega 2560 or Due)
- In file 'mower.h', choose the correct PCB (PCB_1_2 or PCB_1_3)
- In file 'mower.h', choose the correct robot type (ROBOT_ARDUMOWER or ROBOT_MINI)
- In file 'mower.h', choose the correct motor drivers (DRIVER_MC33926 or DRIVER_L298N) - in most cases, DRIVER_MC33926 the correct one
- Upload the code to your Arduino board
- After successfully uploading, open the Arduino IDE serial console and choose baud rate 19200. You should see something like this:
ADCMan: found calib data ---ADC calib--- ADC sampleRate=38462 AD0 min=9999 max=-9999 diff=-19998 ofs=334 AD1 min=9999 max=-9999 diff=-19998 ofs=417 ... SETUP matchSignal size=24 subSample=4 capture size=192 1 0 -1 0 1 -1 1 -1 0 1 -1 1 0 -1 0 1 -1 0 1 -1 0 1 0 -1 IMU error: no calib data
accOfs=0.00,0.00,0.00 accScale=2.00,2.00,2.00 comOfs=0.00,0.00,0.00 comScale=2.00,2.00,2.00
initL3G4200D gyro read error gyro read error gyro read error loadSaveErrorCounters: read loadSaveErrorCounters addrstop=423 loadUserSettings EEPROM USERDATA: NO EEPROM USER DATA PLEASE CHECK AND SAVE YOUR SETTINGS loadSaveRobotStats: read loadSaveRobotStats addrstop=822 START Ardumower 1.0a8-Azurit-dev PCB 1.3 Arduino Mega IOREF=5.00 Robot: Mini press...
d for menu v to change console output (sensor counters, values, perimeter etc.)
sen_counters t 1 L 0 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 677.0 chg 677.0 0.0 imu 0 adc 0 Mini
First-time usage
2. The software offers a serial console mode. Open the serial console in the Arduino IDE (CTRL+SHIFT+M) and set the baudrate to 19200. The motor and sensor values should appear constantly. First let's delete any existing error. Send the letter 'd' to the Arduino.
pres... 8=ADC calib (perimeter sender, charger must be off)
4. Save user settings
press... 9=saver user settings
5. Test motors:
press... 1=test motorsSecurity note: For security reasons, always remove mower blades in your first tests!
Starting the mower
Console output
--- commands ---
Bluetooth module
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
Communication protocol
Sensor logging
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes
ERR_CPU_SPEED CPU speed error
ERR_IMU_TILT IMU tilt error
* Check coil polarity
* Check left odometry cable
* Check left motor direction
* Check right odometry cable
* Check right motor direction
ERR_BATTERY Battery error
* Check battery connections
ERR_CHARGER Charger error
* Check charger connections
* Check GPS cables
ERR_GPS_DATA GPS data error
* Check GPS antenna and cable
I2C errors
Sensor logging
Charging
IMU
IMU sensor fusion
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
GPS
Currently, GPS is used
Visualization of GPS data
GPS error
Timer
Timer 3: off
Timer 4: off
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Dropcontact = 1; ändern in 0
Implemented updates:
