Azurit Firmware (English)
Version vom 11. Juli 2017, 13:45 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Receiver ADC calibration)
Uploading the Arduino code to your Arduino
// #define PCB_1_2
#define PCB_1_3
Serial console
ADCMan: found calib data
---ADC calib---
ADC sampleRate=38462
SETUP
matchSignal size=24
subSample=4
capture size=192
IMU error: no calib data
accOfs=0.00,0.00,0.00
accScale=2.00,2.00,2.00
comOfs=0.00,0.00,0.00
comScale=2.00,2.00,2.00
initL3G4200D
gyro read error
gyro read error
gyro read error
loadSaveErrorCounters: read
loadUserSettings
loadSaveRobotStats: read
START
Robot: Mini
press...
 d for menu
sen_counters
Motor test
MAIN MENU:
1=test motors
2=test odometry
3=communications menu
5=calibrate IMU acc next side
7=delete IMU calib
9=save user settings
c=test RTC
l=load factory settings
r=delete robot stats
x=print settings
e=delete all errors
0=exit
Odometry
First run
Sensor counters and sensor values
m0  - sensor trigger counters  (default view)
m1  - current sensor values
m2  - perimeter values​​
t     4 L177 m0  ...
t   - time of current machine state (FORW, REV, ROLL, etc.) (ms)
L   - loop () - cycles per second
m   - console output mode (0 = sensor trigger counters / 1 = current sensor values ​​/ 2 = perimeter values​​)
sen - motor current overflow counter:  left wheel, right wheel, mower motor
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
Console commands
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
Bluetooth module
 0=Main Menu
send: AT
send: AT
 received: OK
=>success
detecting BT type...
send: AT+VERSION
send: AT+VERSION?
OK
=>must be a HC03/04/05 ?
setting name Mini...
send: AT+NAME=Mini
 received: OK
=>success
setting pin 1234...
send: AT+PSWD=1234
 received: OK
=>success
setting baudrate 19200...
send: AT+UART=19200,0,0
 received: OK
=>success
8. You need to pair the bluetooth module it with your Android device. On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin ("1234"). The Bluetooth module should now appear as "paired". Try to connect using ArduRemote App with your robot. You should get a menu like this on your Android device:
Pfod cmd= {.}
Sensor logging
Motor controller (PID)
Charging
Timer/RTC
MAIN MENU:
1=test motors
2=test odometry
7=delete IMU calib
c=test RTC
Timer 3: off
Timer 4: off
IMU
                noise dps/sqrt(Hz)
L3G4200D        0.03
ITG3200         0.03
L3GD20          0.03
BMG160/BNO055   0.014
MPU9250         0.01
L3GD20H         0.011
LSM9DS0         0.00875
BMI160          0.007
MAX21003        0.007
L2G2IS/L2G3IS   0.006
MPU9150/MPU6050 0.005
ADXRS290        0.004
CRM100/200      0.003
GYPRO2300       0.00277
LSM303DLM
IMU sensor fusion
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
IMU calibration steps
Calibration quality test
Perimeter receiver
The perimeter settings are:
Warning.png Before the perimeter receiver can be used, the ADC pin has to be calibrated. The ADC calibration ensures that the zero point (silence) is detected correctly, and so later the received signal is symmetric around zero.
  3. Run the ADC calibration once ("pfodApp->ADC Calibration" or via serial console 'main menu->ADC calib')
GPS
Currently, GPS is used
Visualization of GPS data
spd     ground speed m/s
course  ground course degree
alt     altitude meter
lat     latitude
lon     longitude
GPS error
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Finite state machine
Implemented updates:
Diagnostics/troubleshooting
Sensor errors
  2. loop()-counts per second
  5. drive home? (1/0)
  11. "com" - compass course
  13. "bat" - Battery voltage
  14. "chg" - Charging current
Hardware measurements
Error codes
 ERR_CPU_SPEED           CPU speed error
 ERR_MOTOR_LEFT          Left gear motor error
                         * Check coil polarity
                         * Check left odometry cable
                         * Check left motor direction
                         * Check right odometry cable
                         * Check right motor direction
                         * Check battery connections
                         * Check charger connections
                         * Check GPS cables
                         * Check GPS antenna and cable
Console:
press...
d for menu
e=delete all errors
I2C errors
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Robot not stopping to rotate when reaching perimeter (home mode)
More troubleshooting
