Ardumower Sunray
- 8 PCB1.3 GPS pin fix and GPS wire fix
- 9 PCB1.3 odometry divider
- 11 RTK base
- 12 RTK rover
- 15 Phone App
- 16 Odometry test
- 17 Position source mode
- 22 GPS checksum errors
- 25 IMU, sensor fusion
- 26 Ultrasonic sensor
- 27 Bumper sensor
- 28 Extending WiFi range with outdoor access point
- 29 Portable WiFi router for NTRIP
- 30 Longer battery operation time
- 31 Automatic battery switch off
- 32 Docking
- 33 WiFi module
- 34 Bluetooth Low Energy (BLE) and WiFi external antenna
- 35 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 36 Troubleshooting
- 37 How to record GPS data
- 38 Datasheets
- 39 Data privacy
- 40 Discussion / questions / forum thread
- 41 SD card module
- 42 SD card logging
- 43 R/C model
- 44 Hardware debugging
- 45 XBee module configuration
- 46 Firmware Console Debugging
- 47 Further links
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin ('GPS wire fix')
- Remove jumper Gps_S (JP12)
| PCB 1.3 | PCB 1.4 |
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
- Start XCTU
Channel Mask: 3EFFFDFF Network ID: 1985 Broadcast Multi-Transmits: 3 RD Data Rate: 80 kps TX Power Level: 32 mW Unicast Retries: A - Routing/Messaging Mode: Standard Router[0] Broadcast Hops: 0 Network Hops: 7 Mesh Unicast Retries: 1 - Destination Address High: 0 Destination Address Low: FFFF Transmit Options: 40 Node Identifier: Network Discovery Back-off: 82 Network Discovery Options: 0 Cluster ID: 11 - Encryption: Disabled [0] AES Encryption Key: - Baud Rate: 115200 Parity: No Parity [0] Stop Bits: One stop bit [0] Packetization Timeout: 3 Flow Control Threshold: 11D API Enable: Transparent Mode [0] API Options: API Rx Indicator - 0x90 [0] - DIO0: Commissioning Button DIO1: Disabled DIO2: Disabled DIO3: Disabled DIO4: Disabled DIO5: Assoc. Indicator DIO6: Disabled DIO7: CTS flow control DIO8: Sleep Request DIO9: ON/SLEEP Output DI10: RSSI PWM0 Output DI11: Disabled DI12: UART_DOUT DOUT: UART_DIN DI15: SPI_MISO DI16: SPI_MOSI DI17: SPI_SSEL DI18: SPI_SCLK DI19: SPI_ATTN Pull Direction: FFFFF Pull-Up: FFFFF PWM0: 0 PWM1: 0 Associate LED Blink Time: 0 RSSI PWM Timer: 28 - Sleep Mode: Normal Sleep Options: 2 Number of Cycles Between Sleep: 1 Sleep Time: 190 Wake Time: 1F40 Wake Host Delay: 0
