AzuritBer Firmware (English)
Version vom 5. Februar 2022, 11:19 Uhr von Bernard (Diskussion | Beiträge) (→‎Raspberry PI + Rfid reader)
GITHUB Location
It's here:
GITHUB REPOSITORY
What is AzuritBer and Why
https://youtu.be/Abt5pcWz2H0
https://youtu.be/T5mH4yMyWus
WIFI ESP32 Sender
if you have only one mowing area , you can use sender from shop : sender start when mower leave station and stop when mower is back or after a 5 hours timeout.
WIFI and MQTT
Full description is here :
RFID READER
Raspberry PI
It's Level 1 but now:
Standard Setup
Hardware is standard one : the PCB1.3 or 1.4 and simple BT module HC05
Install Firmware in DUE
are set like that : uncomment #define Console Serial to receive Console message inside your PC arduino ide console and comment #define Console SerialUSB
Arduremote or PFOD APP
Main
Command
Arduremote
Possible value are :
Button connected on P20
If mower is in OFF state:
If mower is running:
Push it to stop immediately
Console
Setting
Here the setting page.
Set Force mowing off to YES
ODOMETRY Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
MOTOR Setting
See PID Control : [1]
MOW setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
STATION setting
PERIMETER setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
Reduce Speed Near Wire
Actual Speed Coeff
IMU Wiring and Setting
MPU-9250 IMU WIRING TO PCB1.3
 IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
 ADO <-> IMU VCC
GY-88 IMU WIRING TO PCB1.3
 IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
 G_ADO <-> IMU VCC
IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
 ADO <-> IMU VCC
IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
GY-87 WIRING TO PCB1.3
 IMU       PCB
 VCC_IN <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
IMU Main Setting
IMU Use
Stop Mow Motor During Calib
P I D
Calibration Max Duration
Delay between 2 calib
'Drift Maxi in Deg per Second
Speed to find ComYaw
SETTING Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
SETTING With Compass
CONSOLE SHOW :
TIMER setting
BYLANE setting
BATTERY setting
Charge Factor
Battery Factor
Sense Factor
Go Home if Volt below
Switch off after minutes
Switch off if Volt below
Start charge if Voltage below
Stop charge if Sense below
SONAR setting
Sonar brake below
Sonar To Front Dist
RAIN TEMP setting
Rain Use
DHT22Use
Maximum Temperature
OLED Screen setting
#define Enable_Screen true
In OFF mode :
While mower running :
When Charging :
Level 2 Raspberry Pi
Level 3 Raspberry Pi + RFID
