AzuritBer Firmware (English)
- 1 GITHUB Location
- 2 Test requirements
- 3 What is AzuritBer and Why
- 4 Possible Option
- 5 First start Level 1
- 6 Level 2 Raspberry Pi
GITHUB Location
It's here:
WIFI ESP32 Sender
It's here: https://wiki.ardumower.de/index.php?title=WIFI_Perimeter_Sender(English)
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
First start Level 1
Setting
Note that the MPU-9250 is not always working perfectly,On some 9250 chips you can see randomly I2C RTC error .So it's better to use GY-88 or GY-521
CONSOLE SHOW :
Set Force mowing off to YES
ODOMETRY Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
MOTOR Setting
See PID Control : [1]
MOW setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
STATION setting
PERIMETER setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
IMU Wiring and Setting
MPU-9250 WIRING TO PCB1.3
GY-88 WIRING TO PCB1.3
GY-521 WIRING TO PCB1.3
GY-521 don't have a compass ,so you need to deactivate Compass into arduremote/setting/IMU.
GY-87 WIRING TO PCB1.3
IMU Main Setting
IMU Use
Compass Use
If your IMU is locate near electronics or motor ,It's better to deactivate the compass : Bylane mowing can result on drifting parallel lane without compass but not always an issue in normal mowing condition.
Stop Mow Motor During Calib
P I D
Calibration Max Duration
Delay between 2 calib
'Drift Maxi in Deg per Second
Speed to find ComYaw
SETTING Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
SETTING With Compass
CONSOLE SHOW :
TIMER setting
BYLANE setting
BATTERY setting
Charge Factor
Battery Factor
Sense Factor
Go Home if Volt below
Switch off after minutes
Switch off if Volt below
Start charge if Voltage below
Stop charge if Sense below
SONAR setting
Sonar brake below
Sonar To Front Dist
RAIN TEMP setting
Rain Use
DHT22Use
Maximum Temperature
