Ardumower Sunray
- 4 Requirements
- 8 PCB1.4 GPS
- 10 PCB1.3 odometry divider
- 12 RTK base
- 13 RTK rover
- 16 Phone App
- 17 Odometry test
- 18 Position source mode
- 23 GPS checksum errors
- 26 IMU, sensor fusion
- 27 Ultrasonic sensor
- 28 Bumper sensor
- 33 Docking
- 34 WiFi module
- 37 Troubleshooting
- 38 How to record GPS data
- 39 Datasheets
- 40 Data privacy
- 42 SD card module
- 43 SD card logging
- 44 R/C model
- 45 Hardware debugging
- 48 Further links
- Remove jumper Gps_S (JP12)
| PCB 1.3 | PCB 1.4 |
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
- Start XCTU
