Ardumower Sunray
Version vom 4. Februar 2022, 08:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Method 2: Using an RTK external base service (Internet-based))
RTK-GPS uses two GPS receivers, one for the reference antenna (base) and one for the robot mower (rover) which both communicate in realtime via radio modules (see image below). The base constantly sends correction data so the rover can compute its cm-precise (relative) position. In the RTK-GPS kit, everything required (receivers, radios, antennas etc.) is included. Also, if you don't want to operate your own RTK base, you can use an external base service via Internet (e.g. like SAPOS in Germany, FLEPOS in the Netherlands). This will reduce the hardware cost by about a half. If using your own RTK base, long-range radio modules (e.g. 868 Mhz) are preferred over standard 2.4 Ghz radio modules as they better penetrate buildings, trees etc. NOTE: Using your own RTK base is highly recommended as this will give most robust (RTK fix) position results!
  2. Remove jumper Gps_S (JP12)
PCB 1.3 PCB 1.4
F0-00 F0-00 NMEA GxGGA    60
PCB PCB PCB
volt=24
...some time later...
...many time later...
Automatic robot switch off
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
  3. Start XCTU
  6. Settings found on the XBee SX 868 (Firmware version A007) - The sections marked in red are important:
Channel Mask: 3EFFFDFF
Network ID: 1985
Broadcast Multi-Transmits: 3
RD Data Rate: 80 kps
TX Power Level: 32 mW
Unicast Retries: A
Broadcast Hops: 0
Network Hops: 7
Mesh Unicast Retries: 1
Destination Address High: 0
Destination Address Low: FFFF
Transmit Options: 40
Node Identifier:
Network Discovery Options: 0
Cluster ID: 11
Encryption: Disabled [0]
AES Encryption Key:
Baud Rate: 115200
Parity: No Parity [0]
Stop Bits: One stop bit [0]
Packetization Timeout: 3
Flow Control Threshold: 11D
DIO0: Commissioning Button
DIO1: Disabled
DIO2: Disabled
DIO3: Disabled
DIO4: Disabled
DIO5: Assoc. Indicator
DIO6: Disabled
DIO7: CTS flow control
DIO8: Sleep Request
DIO9: ON/SLEEP Output
DI10: RSSI PWM0 Output
DI11: Disabled
DI12: Disabled
DOUT: UART_DOUT
DIN:  UART_DIN
DI15: SPI_MISO
DI16: SPI_MOSI
DI17: SPI_SSEL
DI18: SPI_SCLK
DI19: SPI_ATTN
Pull Direction: FFFFF
Pull-Up: FFFFF
PWM0: 0
PWM1: 0
Associate LED Blink Time: 0
RSSI PWM Timer: 28
Sleep Mode: Normal
Sleep Options: 2
Sleep Time: 190
Wake Time: 1F40
Wake Host Delay: 0
