Ardumower Sunray
- 4 Requirements
- 8 PCB1.4 GPS
- 10 PCB1.3 odometry divider
- 12 RTK base
- 13 RTK rover
- 16 Phone App
- 17 Odometry test
- 18 Position source mode
- 23 GPS checksum errors
- 26 IMU, sensor fusion
- 27 Ultrasonic sensor
- 28 Bumper sensor
- 33 Docking
- 34 WiFi module
- 37 Troubleshooting
- 38 How to record GPS data
- 39 Datasheets
- 40 Data privacy
- 42 SD card module
- 43 SD card logging
- 44 R/C model
- 45 Hardware debugging
- 48 Further links
These are the hardware requirements to add RTK-GPS to your Ardumower. You can purchase the required hardware from Marotronics .
- Incomplete (Sunray is 'work in progress') - all features like docking, GPS signal-loss detection, obstacle detection and avoidance are experimental and features like mowing zones, improved path planning, smart home integration (e.g. MQTT) are going to be added later...
- Experimental: everything you see in the videos is already working but in early prototype phase (never run your Ardumower unattended with this firmware)!
- Only-works-as-a-whole: all software, hardware and motor components are designed and optimized as a whole, if you try to replace or exclude some component not as designed, you risk to damage your hardware with the software
- Remove jumper Gps_S (JP12)
PCB 1.3 | PCB 1.4 |
Add external resistors (2k2 Ohm) on Grand Central M4. |
1001: L1-only RTK observables 1002: Extended L1-only RTK observables 1003: Compact L1&L2 observables 1004: Extended L1&L2 observables
--> 1005: Stationary RTK reference station ARP 1006: Stationary RTK reference station ARP with height 1007: Antenna descriptor *1008: Antenna descriptor and serial number
1009: L1-only GLONASS observables 1010: Extended L1-only GLONASS observables 1011: GLONASS basic RTK L1&L2 1012: GLONASS extended RTK L1&L2 *1013: System parameters *1019: GPS ephemeris data *1020: GLONASS ephemeris data *1021: Helmert/Abridged Molodenski Transformation Parameters *1023: Residuals, Ellipoidal Grid Representation *1025: Projection Parameters, Projection Types other than Lambert Conic Conformal *1032: Physical Reference Station Position 1033: Receiver and antenna descriptors
*1073: GPS MSM3 *1083: GLONASS MSM3 *1093: GALILEO MSM3 *1123: Beidou MSM3
1075: GPS MSM5 1085: GLONASS MSM5 1095: GALILEO MSM5 1125: Beidou MSM5
1077: GPS MSM7 1087: GLONASS MSM7 1097: GALILEO MSM7 1127: Beidou MSM7
GPS G1,G2,G3,... L1C/A L2CL L2CM GLONASS R1,R2,R3,... L1OF L2OF GALILEO E1,E2,E3,... E1C E5BQ Beidou B1,B2,B3,... B1D1
F0-00 F0-00 NMEA GxGGA 60
invalid | no DGPS solution was found |
float | DGPS solution was found but it is ambiguous and therefore not precise (average error ~20cm). |
fix | DGPS solution was found and it is cm-precise - position is tracked in realtime (RTK) |
age | The age (in seconds) of the DGPS correction data sent from base |
relative: the rover coordinates are always relative to the base antenna (recommended - use this when using your own base) - if the base moves after a map recording, you have to switch to absolute mode absolute: the rover coordinates are computed as relative to some specified (e.g. your base antennna or house) world coordinate (see image below - use this when using an NTRIP client or for a different base position)
GPS>XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE>GPS | should be OFF - your base module should not receive any XBee/reference signal |
GPS FIX | should blink - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
GPS>XBEE | should be OFF - your rover module should not send any XBee signal |
XBEE>GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
GPS FIX | should blink - your rover module has found a valid GPS signal |
NO RTK | should be OFF - your rover module has found a RTK FLOAT or FIX (is performing real-time kinematic) |
Min SV Elevation: 10 [deg] C/N0 Threshold : 0 [#SVs] 0 [dbHz]
Min SV Elevation: 10 [deg] C/N0 Threshold : 10 [#SVs] 30 [dbHz]
PRT (ports) protocol UART2 (XBee) in: RTCM3 protocol UART2 (XBee) out: RTCM3 baudrate UART2 (XBee): 115200 baud RATE (rates) measurement period: 1000ms (1 Hz) TMOD3 (Time mode3) mode: Fixed mode Fixed Position: Your base lat/lon coordinates MSG (messages) for UART2 (XBee) transmit frequency (10 means message is sent every 10 solutions): F5-05 RTCM3.3 1005 Stationary ARP 1 F5-4A RTCM3.3 1074 GPS MSM4 1 F5-54 RTCM3.3 1084 GLONASS MSM4 1 F5-5E RTCM3.3 1094 GALILEO MSM4 1 F5-7C RTCM3.3 1124 Beidou MSM4 1 F5-E6 RTCM3.3 1230 GLONASS code-phase 1
additional activated messages (or changed message frequency) for UART1+USB: MSG (messages) for UART1(Ardumower)+USB transmit frequency (60 means message is sent every 60 solutions) F0-00 NMEA-GxGGA 60 01-07 UBX-NAV-PVT 10 01-12 UBX-NAV-VELNED 1 01-14 UBX-NAV-HPPOSLLH 1 01-3C UBX-NAV-RELPOSNED 1 01-43 UBX-NAV-SIG 10 02-32 RXM-RTCM 5 additional activated messages for UART2(XBee)+USB: MSG (messages) F0-00 F0-00 NMEA GxGGA 60 RATE (rates) measurement period: 200ms (5 Hz) PRT (ports) baudrate UART1 (Ardumower): 115200 baudrate UART2 (XBee): 115200 protocol in UART1 (Ardumower): UBX+NMEA protocol out UART1 (Ardumower): UBX+NMEA protocol out UART2 (XBee): NMEA protocol in UART2 (XBee): RTCM3 NAV5 (navigation 5) input filter: Min SV elevation 10 default: 10 C/N0 Threshold #SVs 10 0 dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
> C:\Users\alex\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4\bin>arm-none-eabi-gdb c:\users\alex\AppData\local\temp\arduino_build_408598\sunray.ino.elf
- Start XCTU
