Azurit Firmware (English)
- 1 Download and flash Arduino code
- 2 Settings
- 3 First-time usage
- 4 Starting the mower
- 5 Console output
- 6 Bluetooth module
- 7 Diagnostics/troubleshooting
- 8 Sensor logging
- 9 How to report a new bug/new feature/new code
- 10 Charging
- 11 IMU
- 12 IMU calibration steps
- 13 Perimeter receiver
- 14 Finite state machine
- 15 GPS
You have two options:
Important for Arduino IDE 1.6 or higher: if you see any folders inside the code folder (e.g. 'unused'), please delete them before compilation! Note: Always verify that the pin configuration in your Arduino code (config.h/mower.cpp) matches your actual circuit!
First-time usage
2. The software offers a serial console mode. Open the serial console in the Arduino IDE (CTRL+SHIFT+M) and set the baudrate to 19200. The motor and sensor values should appear constantly. First let's delete any existing error. Send the letter 'd' to the Arduino.
pres... 8=ADC calib (perimeter sender, charger must be off)
4. Save user settings
press... 9=saver user settings
5. Test motors:
press... 1=test motorsSecurity note: For security reasons, always remove mower blades in your first tests!
Starting the mower
Console output
--- commands ---
Bluetooth module
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
Communication protocol
Sensor logging
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Hardware measurements
Error codes
ERR_CPU_SPEED CPU speed error
ERR_IMU_TILT IMU tilt error
* Check coil polarity
* Check left odometry cable
* Check left motor direction
* Check right odometry cable
* Check right motor direction
ERR_BATTERY Battery error
* Check battery connections
ERR_CHARGER Charger error
* Check charger connections
* Check GPS cables
ERR_GPS_DATA GPS data error
* Check GPS antenna and cable
I2C errors
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Robot not stopping to rotate when reaching perimeter (home mode)
Sensor logging
Charging
IMU
IMU sensor fusion
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
Implemented updates:
GPS
Currently, GPS is used
Visualization of GPS data
GPS error
