Perimeter sender (English)
Version vom 4. Juli 2017, 09:58 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Download and flash Arduino code)
How is the signal detected? The signal is detected by one receiver coils. The closer the distance between coil and perimeter loop, the higher the signal strength. Also, something interesting happens when the robot crosses the perimeter loop: the signal changes its polarity, that means positive and negative voltages reverse each other.
Charging station
Required parts for a perimeter loop
A perimeter loop is optional but recommended.
Perimeter
Sender principle:
Receiver principle:
  1. A coil receives the signal
Note for Marotronics INA169: Short pads for 5A operation
  1. Download an Ardumower Release at Github - You will find the sender code in the folder 'sender' of the downloaded release
  2. Download the Arduino IDE to flash the code to your Arduino
Arduino Version: It is very Importent that you use the Arduino IDE version 1.6.3 or above AND select the right Board (Nano).
Sender power control
Power:  P = U * I = 8 Volt * 0.7 Ampere => 5.6 Watt
Sender automatic standby
Sender diagnostics
Receiver
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Broken perimeter wire
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
  5. Perimeter stop test
  6. Perimeter tracking test
