Perimeter sender (English)
How is the signal detected? The signal is detected by one receiver coils. The closer the distance between coil and perimeter loop, the higher the signal strength. Also, something interesting happens when the robot crosses the perimeter loop: the signal changes its polarity, that means positive and negative voltages reverse each other.
Charging station
Required parts for a perimeter loop
A perimeter loop is optional but recommended.
- Perimeter sender PCB
- Optional modules:
- PCB case including 5 screws
- Connecting terminals 3x (2x Perimeter loop, 1x Charger)
- Socket for case 2,5
- Additional accessories depending on needs:
- A charging station is in development and will follow soon.
Perimeter
Sender principle:
Receiver principle:
- A coil receives the signal
The perimeter wire length should be in the range 20m - 450m and must be at least 5 Ohm and not more than 12 Ohm. The maximum perimeter area is 1000 m2.
NOTE: If you have never worked with Arduino before, read our 'Arduino first steps' introduction (it also contains useful information if your Arduino will not flash).
- Download an Ardumower Release at Github - You will find the sender code in the folder 'sender' of the downloaded release
- Download the Arduino IDE to flash the code to your Arduino
Arduino Version: It is very Importent that you use the Arduino IDE version 1.6.3 or above AND select the right Board (Nano).
Sender power control
The perimeter wire resistance (R) must be at least 5 Ohm and not more than 12 Ohm. Ideally, a 12 ohms (50W) power resistor is placed in series with the perimeter wire, so you get a total resistance of the perimeter wire at 12-15 ohms.
Your perimeter wire resistance (R): 12 Ohm Your adjusted voltage at the DC/DC converter: 8 Volt
Current: I = U / R = 8 Volt / 12 Ohm => 0.7 Ampere Power: P = U * I = 8 Volt * 0.7 Ampere => 5.6 Watt
Sender automatic standby
Sender diagnostics
Receiver
Signal measurements
Broken perimeter wire
- Perimeter2 demo
- 120m perimeter wire test
- Sender PCB
- Perimeter stop test
- Perimeter tracking test
