Azurit Firmware (English)
Version vom 5. Juli 2017, 15:40 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Uploading the Arduino code to your Arduino)
1. Download an Ardumower Release at Github 2. Download the Arduino IDE that we will use to upload the code to your Arduino 3. Start Arduino IDE, and choose the right Arduino board (either Mega 2560 or Due) 4. In file 'mower.h', choose the correct PCB (PCB_1_2 or PCB_1_3) - Example for choosing PCB 1.3 (a line started with // will be ignored):
// #define PCB_1_2
#define PCB_1_3
5. In file 'mower.h', choose the correct robot type (ROBOT_ARDUMOWER or ROBOT_MINI) 6. In file 'mower.h', choose the correct motor drivers (DRIVER_MC33926 or DRIVER_L298N) - in most cases, DRIVER_MC33926 is the correct one 7. Upload the code to your Arduino board
Serial console
ADCMan: found calib data
---ADC calib---
ADC sampleRate=38462
SETUP
matchSignal size=24
subSample=4
capture size=192
IMU error: no calib data
accOfs=0.00,0.00,0.00
accScale=2.00,2.00,2.00
comOfs=0.00,0.00,0.00
comScale=2.00,2.00,2.00
initL3G4200D
gyro read error
gyro read error
gyro read error
loadSaveErrorCounters: read
loadUserSettings
loadSaveRobotStats: read
START
Robot: Mini
press...
 d for menu
sen_counters
First-time usage
bumperUse = 0;
dropUse = 0;
rainUse = 0;
sonarUse = 0;
perimeterUse = 0;
lawnSensorUse = 0;
imuUse = 0;
batMonitor = 0;
odometryUse = 0;
gpsUse = 0;
buttonUse = 1;
timerUse = 0;
2. The software offers a serial console mode. Open the serial console in the Arduino IDE (CTRL+SHIFT+M) and set the baudrate to 19200. The motor and sensor values should appear constantly. First let's delete any existing error. Send the letter 'd' to the Arduino.
Console:
press...
d for menu
e=delete all errors
pres...
4. Save user settings
press...
9=saver user settings
5. Test motors:
press...
1=test motors
Starting the mower
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
- After-home-drive? (1/0)
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
--- commands ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
Motor controller (PID)
Bluetooth module
  • via phone/tablet (Android App)
  • via USB Bluetooth dongle (PC serial console)
The phone menu includes:
  • Status information (battery voltage, charging current etc.)
  • Settings (Timer etc.)
  • Calibration (Motor, IMU etc.)
  • Remote control (Start/Stop, Switching on/off mower motor, blade modulation etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
  1. Configuration mode: The Bluetooth module must be in configuration mode for the next step:
    1. for HC05: Connect KEY pin to 3.3V after powering on the module
    2. for HC06/linvor: Do NOT pair/connect (LED must be blinking)
    3. for FBT06/MBTV4: First you have to solder the PIO11 pin to VCC (PIN 12) which is 3.3 Volts using a thin wire.
  2. Baud rate: Blueooth module and Arduino Mega must use the same baud rate (19200) - The baud rate of the BT module can be changed via Ardumower serial console. Connect Ardumower Mega board to your PC (USB), enter the serial console in the Arduino IDE (CTRL+M), and choose baud rate 19200, then choose 'd' to enter the Ardumower menu, '3' for communications menu, and '3' to configure the module to the correct baud rate.
  3. Restart: After your BT module is configured successfully, remove KEY pin connection again (HC05), and restart module.
  4. Pairing: The BT module must be 'paired' with your Android device once (via Android device settings). On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired".
  5. pfodApp: Now you can start pfodApp/ArduRemote to connect to the Ardumower.
Communication protocol
Sensor logging
  1. menu demo v0.8.8
  2. menu demo live v0.8.8
  3. tutorial video
Diagnostics/troubleshooting
  2. loop()-counts per second
  5. drive home? (1/0)
  11. "com" - compass course
  13. "bat" - Battery voltage
  14. "chg" - Charging current
Hardware measurements
Error codes
 ERR_CPU_SPEED           CPU speed error
 ERR_MOTOR_LEFT          Left gear motor error
                         * Check coil polarity
                         * Check left odometry cable
                         * Check left motor direction
                         * Check right odometry cable
                         * Check right motor direction
                         * Check battery connections
                         * Check charger connections
                         * Check GPS cables
                         * Check GPS antenna and cable
Console:
press...
d for menu
e=delete all errors
I2C errors
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Robot not stopping to rotate when reaching perimeter (home mode)
More troubleshooting
Sensor logging
Charging
IMU
                noise dps/sqrt(Hz)
L3G4200D        0.03
ITG3200         0.03
L3GD20          0.03
BMG160/BNO055   0.014
MPU9250         0.01
L3GD20H         0.011
LSM9DS0         0.00875
BMI160          0.007
MAX21003        0.007
L2G2IS/L2G3IS   0.006
MPU9150/MPU6050 0.005
ADXRS290        0.004
CRM100/200      0.003
GYPRO2300       0.00277
LSM303DLM
IMU sensor fusion
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
IMU calibration steps
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
GPS
Currently, GPS is used
Visualization of GPS data
spd     ground speed m/s
course  ground course degree
alt     altitude meter
lat     latitude
lon     longitude
GPS error
Timer
Timer 3: off
Timer 4: off
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Finite state machine
Implemented updates:
