Azurit Firmware (English)
- 1 Test requirements
- 3 Serial console
- 4 Motor test
- 5 Odometry
- 6 First run
- 7 Sensor counters and sensor values
- 8 Console commands
- 9 Bluetooth module
- 10 Motor controller (PID)
- 11 Charging
- 12 Timer/RTC
- 13 IMU
- 14 IMU calibration steps
- 15 Perimeter receiver
- 16 GPS
- 17 Drop sensor
- 18 Finite state machine
- 19 How to report a new bug/new feature/new code
- 20 Diagnostics/troubleshooting
- 20.1 Sensor errors
- 20.2 Hardware measurements
- 20.3 Error codes
- 20.4 I2C errors
- 20.5 Disable all pins not connected
- 20.6 Motors working correctly
- 20.7 Any unexpected sensor triggering
- 20.8 Some sensor not triggering?
- 20.9 Bluetooth not connecting?
- 20.10 Robot not stopping to rotate when reaching perimeter (home mode)
- 20.11 More troubleshooting
Serial console
Motor test
testing left motor (forward) half speed... t 741 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 742 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 743 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 744 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 745 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing left motor (reverse) full speed... t 747 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 748 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 749 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 751 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 752 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing right motor (forward) half speed... t 754 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 755 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 756 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 757 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 758 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing right motor (reverse) full speed... t 760 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 761 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 762 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 763 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 764 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini
Odometry
First run
t 4 L177 m0 ...
Console commands
Bluetooth module
The Ardumower can be monitored and controlled via an Android device (phone/tablet). Before you can use the Android App, you have to configure the bluetooth module on the robot so it matches the baud rate in the robot code.
6. After the module has been properly configured, download the App 'ArduRemote' on your Android device. Alternatively, you can use the App 'pfodApp'.
7. You need to pair the bluetooth module it with your Android device. On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin ("1234"). The Bluetooth module should now appear as "paired". Try to connect your Android with your robot. You should get a menu like this on your Android device:
Sensor logging
Charging
Timer/RTC
Timer 3: off
Timer 4: off
IMU
IMU sensor fusion
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
GPS
Currently, GPS is used
Visualization of GPS data
GPS error
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Dropcontact = 1; ändern in 0
Implemented updates:
Sensor errors
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes
ERR_CPU_SPEED CPU speed error
ERR_IMU_TILT IMU tilt error
* Check coil polarity
* Check left odometry cable
* Check left motor direction
* Check right odometry cable
* Check right motor direction
ERR_BATTERY Battery error
* Check battery connections
ERR_CHARGER Charger error
* Check charger connections
* Check GPS cables
ERR_GPS_DATA GPS data error
* Check GPS antenna and cable
I2C errors
