Azurit Firmware (English)
- 1 Test requirements
- 3 Settings
- 4 Serial console
- 5 Motor test
- 6 Odometry
- 7 First run
- 9 Console commands
- 10 Bluetooth module
- 11 Motor controller (PID)
- 12 Charging
- 13 Timer/RTC
- 14 IMU
- 15 IMU calibration steps
- 16 Perimeter receiver
- 17 GPS
- 18 Drop sensor
- 19 Finite state machine
- 21.1 Sensor errors
- 21.2 Hardware measurements
- 21.3 Error codes
- 21.4 I2C errors
- 21.5 Disable all pins not connected
- 21.6 Motors working correctly
- 21.7 Any unexpected sensor triggering
- 21.8 Some sensor not triggering?
- 21.9 Bluetooth not connecting?
- 21.10 Robot not stopping to rotate when reaching perimeter (home mode)
- 21.11 More troubleshooting
Important: If you upload a new Firmware version into your robot and you do not want to use any old/modified settings, you have to reset all settings (via pfodApp: 'Settings->Factory reset' or via console 'main menu->load factory settings'), so the uploaded settings take place.
Serial console
Motor test
testing left motor (forward) half speed... t 741 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 742 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 743 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 744 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 745 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing left motor (reverse) full speed... t 747 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 748 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 749 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 751 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 752 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing right motor (forward) half speed... t 754 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 755 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 756 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 757 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 758 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing right motor (reverse) full speed... t 760 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 761 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 762 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 763 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 764 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini
Odometry
First run
t 4 L177 m0 ...
Console commands
Bluetooth module
The Ardumower can be monitored and controlled via an Android device (phone/tablet). Before you can use the Android App, you have to configure the bluetooth module on the robot so it matches the baud rate in the robot code.
6. After the module has been properly configured, download the App 'ArduRemote' on your Android device. Alternatively, you can use the App 'pfodApp'.
7. You need to pair the bluetooth module it with your Android device. On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin ("1234"). The Bluetooth module should now appear as "paired". Try to connect your Android with your robot. You should get a menu like this on your Android device:
Sensor logging
Charging
Timer/RTC
Timer 3: off
Timer 4: off
IMU
IMU sensor fusion
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
sig: coil signal (raw pulse sequence after ADC) - it's a short snapshot (32 samples), and it's taken every 20 seconds (so you need to wait 20 seconds for the next snapshot) mag: filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire/magnetic signal strength (RSSI) - this is used for perimeter tracking smag: filter result, low-pass filtered, without sign (smooth mag) - this is used for 'sender-off' detection The threshold can bet set via pfodApp (Settings->Perimeter->Timed-out if below smag) in: binary result, low-pass filtered: inside (1) oder outside (0) - this is used for perimeter boundary detection If the robot is not inisde for a certain time, it will go into error. The threshold can bet set via pfodApp (Settings->Perimeter->Timeout (s) if not inside) cnt: number of "inside-outside" transitions (counter) on: perimeter sender active, robot is inside and smag is high enough (1) or inactive/outside/smag too low (0) qty: signal quality (how distinguisable inside and outside were in filter result computes ratio: match score with template signal / match score with inverse template signal 1.0 means poor quality, you should get 1.5 or higher)
GPS
Currently, GPS is used
Visualization of GPS data
GPS error
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Dropcontact = 1; ändern in 0
Implemented updates:
Sensor errors
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes
ERR_CPU_SPEED CPU speed error * Check I2C cables (e.g. reduce wire length) ERR_MOTOR_LEFT Left gear motor error * Check gear motor driver module and left gear motor (supply voltage, signal lines) * MC33926: ensure SLEW jumper is not set * Tracking: reduce Motor-Max-PWM and Tracking-P to reduce EMF ERR_MOTOR_RIGHT Right gear motor error * Check gear motor driver module and right gear motor (supply voltage, signal lines) * MC33926: ensure SLEW jumper is not set * Tracking: reduce Motor-Max-PWM and Tracking-P to reduce EMF ERR_MOTOR_MOW Mower motor error * Check mower motor driver module and mower motor (supply voltage, signal lines) * MC33926: ensure SLEW jumper is not set * Reduce Motor-Max-Power, so over-current is detected earlier ERR_MOW_SENSE Mower motor over-current * Check mower motor driver module and mower motor * Increase Motor-Max-Power, so over-current is detected later ERR_IMU_COMM IMU communication error * Check IMU module connections ERR_IMU_CALIB IMU calibration error * Start IMU calibration (either via Console or pfodApp->Settings->IMU) ERR_IMU_TILT IMU tilt error * Check IMU module and robot orientation ERR_RTC_COMM RTC communication error * Check RTC module connections, RTC battery etc. ERR_RTC_DATA RTC corrupt data error * Set and save RTC date and time * If the error repeats, change RTC battery ERR_PERIMETER_TIMEOUT Perimeter signal timeout * Check perimeter sender, wire etc. * Check coil polarity * Reduce Perimeter-smag, so timeout is higher * Increase Perimeter-timeout-seconds, so timeout is higher * Check your signal-to-noise ratio is higher than 1.0 ERR_TRACKING Perimeter tracking error * Check perimeter sender, wire etc. * Increase Perimeter-tracking-timeout, so timeout is higher ERR_ODOMETRY_LEFT Left motor odometry error * Check left odometry cable * Check left motor direction ERR_ODOMETRY_RIGHT Right motor odometry error * Check right odometry cable * Check right motor direction ERR_BATTERY Battery error * Check battery connections ERR_CHARGER Charger error * Check charger connections ERR_GPS_COMM GPS communication error * Check GPS cables ERR_GPS_DATA GPS data error * Check GPS antenna and cable ERR_ADC_CALIB ADC calibration error * Start ADC calibration (either via Console or pfodApp->ADC calibration) ERR_EEPROM_DATA EEPROM data error * Save user settings (either via Console or pfodApp->Settings-Save)
I2C errors
