Azurit Firmware (English)
- 1 Test requirements
- 3 Serial console
- 4 Motor test
- 5 Odometry
- 6 First run
- 7 Sensor counters and sensor values
- 8 Console commands
- 9 Settings
- 10 Diagnostics/troubleshooting
- 10.1 Hardware measurements
- 10.2 Error codes
- 10.3 I2C errors
- 10.4 Disable all pins not connected
- 10.5 Motors working correctly
- 10.6 Any unexpected sensor triggering
- 10.7 Some sensor not triggering?
- 10.8 Bluetooth not connecting?
- 10.9 Robot not stopping to rotate when reaching perimeter (home mode)
- 10.10 More troubleshooting
- 11 Sensor logging
- 12 Bluetooth module
- 13 Motor controller (PID)
- 14 Charging
- 15 IMU
- 16 IMU calibration steps
- 17 Perimeter receiver
- 18 GPS
- 19 Timer
- 20 Drop sensor
- 21 Finite state machine
Serial console
Motor test
testing left motor (forward) half speed... t 741 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 742 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 743 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 744 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 745 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing left motor (reverse) full speed... t 747 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 748 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 749 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 751 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 752 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing right motor (forward) half speed... t 754 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 755 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 756 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 757 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 758 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini testing right motor (reverse) full speed... t 760 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 761 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 762 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 763 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini t 764 L5790 m0 OFF rpm 0 0 set 0 0 sen 0 0 0 bum 0 0 dro 0 0 son 0 yaw 0 pit 0 rol 0 bat 6.8 chg 0.1 0.9 imu 0 adc 0 Mini
Odometry
First run
t 4 L177 m0 ...
Console commands
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes
ERR_CPU_SPEED CPU speed error * Check I2C cables (e.g. reduce wire length) ERR_MOTOR_LEFT Left gear motor error * Check gear motor driver module and left gear motor (supply voltage, signal lines) * MC33926: ensure SLEW jumper is not set * Tracking: reduce Motor-Max-PWM and Tracking-P to reduce EMF ERR_MOTOR_RIGHT Right gear motor error * Check gear motor driver module and right gear motor (supply voltage, signal lines) * MC33926: ensure SLEW jumper is not set * Tracking: reduce Motor-Max-PWM and Tracking-P to reduce EMF ERR_MOTOR_MOW Mower motor error * Check mower motor driver module and mower motor (supply voltage, signal lines) * MC33926: ensure SLEW jumper is not set * Reduce Motor-Max-Power, so over-current is detected earlier ERR_MOW_SENSE Mower motor over-current * Check mower motor driver module and mower motor * Increase Motor-Max-Power, so over-current is detected later ERR_IMU_COMM IMU communication error * Check IMU module connections ERR_IMU_CALIB IMU calibration error * Start IMU calibration (either via Console or pfodApp->Settings->IMU) ERR_IMU_TILT IMU tilt error * Check IMU module and robot orientation ERR_RTC_COMM RTC communication error * Check RTC module connections, RTC battery etc. ERR_RTC_DATA RTC corrupt data error * Set and save RTC date and time ERR_PERIMETER_TIMEOUT Perimeter signal timeout * Check perimeter sender, wire etc. * Check coil polarity * Reduce Perimeter-smag, so timeout is higher * Increase Perimeter-timeout-seconds, so timeout is higher * Check your signal-to-noise ratio is higher than 1.0 ERR_TRACKING Perimeter tracking error * Check perimeter sender, wire etc. * Increase Perimeter-tracking-timeout, so timeout is higher ERR_ODOMETRY_LEFT Left motor odometry error * Check left odometry cable * Check left motor direction ERR_ODOMETRY_RIGHT Right motor odometry error * Check right odometry cable * Check right motor direction ERR_BATTERY Battery error * Check battery connections ERR_CHARGER Charger error * Check charger connections ERR_GPS_COMM GPS communication error * Check GPS cables ERR_GPS_DATA GPS data error * Check GPS antenna and cable ERR_ADC_CALIB ADC calibration error * Start ADC calibration (either via Console or pfodApp->ADC calibration) ERR_EEPROM_DATA EEPROM data error * Save user settings (either via Console or pfodApp->Settings-Save)
I2C errors
Sensor logging
Bluetooth module
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
Communication protocol
Sensor logging
Charging
IMU
IMU sensor fusion
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration quality test
Perimeter receiver
The perimeter settings are:
Receiver ADC calibration
sig: coil signal (raw pulse sequence after ADC) - it's a short snapshot (32 samples), and it's taken every 20 seconds (so you need to wait 20 seconds for the next snapshot) mag: filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire/magnetic signal strength (RSSI) - this is used for perimeter tracking smag: filter result, low-pass filtered, without sign (smooth mag) - this is used for 'sender-off' detection The threshold can bet set via pfodApp (Settings->Perimeter->Timed-out if below smag) in: binary result, low-pass filtered: inside (1) oder outside (0) - this is used for perimeter boundary detection If the robot is not inisde for a certain time, it will go into error. The threshold can bet set via pfodApp (Settings->Perimeter->Timeout (s) if not inside) cnt: number of "inside-outside" transitions (counter) on: perimeter sender active, robot is inside and smag is high enough (1) or inactive/outside/smag too low (0) qty: signal quality (how distinguisable inside and outside were in filter result computes ratio: match score with template signal / match score with inverse template signal 1.0 means poor quality, you should get 1.5 or higher)
GPS
Currently, GPS is used
Visualization of GPS data
GPS error
Timer
Timer 3: off
Timer 4: off
Drop sensor
Einstellung im Sketsch:
Verdrahtung:
Dropcontact = 1; ändern in 0
Implemented updates:
