Ardumower WIKI - the construction manual for your Ardumower
Here you get an overview of what is required to build an Ardumower and how an Ardumower works:
Manuals, Basics, Tutorials
PS: The english pages are more up do date
Here you can find detailed manuals for assembling the chassis, assembling the PCB, uploading the software etc.:
English
Deutsch
Firmwares overview
Here you can compare the features of the individual firmwares (e.g. which firmware supports a perimeter wire, which firmware supports RTK etc.)
Warning: All software, hardware and motor components are designed and optimized as a whole, if you try to replace or exclude some component not as designed, you risk to damage your hardware with the designed software.
Azurit
AzuritBer
Raindancer
Sunray
Uses perimeter wire for localization and finding docking station
Uses perimeter wire for managing small passages
Number perimeter receiver coils
1
1
2
Uses RFID tag for localization and finding docking station
Uses GPS RTK for localization and finding docking station
Supports lane-by-lane mowing
Supports multiple distinct mowing areas
3 with WiFi sender
up to 10 GPS maps
Supports IMU for path tracking
optional
mandatory
optional
Supports odometry
optional
mandatory
Supported traction motor positions
front, rear
front, rear
front, rear
front, rear
Supported Arduino boards
Arduino Mega / Arduino Due
Arduino Due only
Arduino Due
Arduino Due / Adafruit Grand Central M4
Supported sensors for obstacle detection and avoidance
ultrasonic, bumper
ultrasonic, bumper, AI vision (experimental)
ultrasonic, bumper
ultrasonic, bumper, GPS
Docking support
✔ (via GPS)
Serial console support
Mower display support
tactile screen for easy use on Raspberry or OLED on PCB
App available
PiArdu with Raspberry Pi / VNC Viewer
Compatible with home automation
over MQTT
More construction kits related to Ardumower / Weitere Projekte rund um den Ardumower
Here are further lawn mower and robot projects for you / Hier gibt es weitere Rasenmäher- und Roboter-Projekte:
Vorlage:Div col
Vorlage:Div col end
